| T-Case/Diff Oil http://auszookers.com/forum/viewtopic.php?f=5&t=45714 |
| Author: | klutched [ Thu Apr 03, 2014 1:23 pm ] |
| Post subject: | T-Case/Diff Oil |
Don't really wanna buy 2 different types of oil, diff calls for 80W90 and t-case 75W90. Can I run the same oil in both if so what should I run? Cheers |
| Author: | bohuler [ Thu Apr 03, 2014 2:22 pm ] |
| Post subject: | Re: T-Case/Diff Oil |
Commercial Vehicles - Light/Medium & 4WD SUZUKI Grand Vitara V6 4x4, 2.5 Litre Eng. (1998-2006) Crankcase PREMIER LITE 10W/30 Service Refill Capacity: 5.5* Litres (see note 159) Manual Transmission GEAR OIL 75W/90 GL-4 Service Refill Capacity: 2.7 Litres Automatic Transmission AUTO TRANSMISSION FLUID (DX3) Service Refill Capacity: 2.5 Litres Differential EP MULTIGEAR 80W/90 GL-5 Service Refill Capacity: 2.2 Litres (see note 15) Power Steering AUTO TRANSMISSION FLUID (DX3) 4WD Transfer GEAR OIL 75W/90 GL-4 Service Refill Capacity: 1.7 Litres 4WD Differential EP MULTIGEAR 80W/90 GL-5 Service Refill Capacity: 1.0 Litres This is straight off my lube guide. The fact that it calls GL-4 and a GL-5 indicates that they have 2 different requirements. |
| Author: | klutched [ Thu Apr 03, 2014 2:38 pm ] |
So that's a no go using the same oil? |
| Author: | Blkfxx [ Thu Apr 03, 2014 2:46 pm ] |
viewtopic.php?f=5&t=20969&hilit=oil+gl5 |
| Author: | klutched [ Thu Apr 03, 2014 3:16 pm ] |
Found this stuff, says where API GL-4 or GL-5 are required. http://productsforyou.castrol.com.au/pr ... s-75W-90/9 |
