http://auszookers.com/forum/
rear wheel bearing
http://auszookers.com/forum/viewtopic.php?f=5&t=4582
Author:  Damo [ Tue Apr 14, 2009 2:18 pm ]
Post subject:  rear wheel bearing
This is a really bad pic (sorry!) of the stock axle shaft and bearing sans backing plate. See how the bearing sits proud of the diff housing flange? Is that normal? I think it is, there seems to be a bit of a recess in the stock backing plate to allow for that, I just want to be sure that's all.
Author:  steve [ Tue Apr 14, 2009 2:28 pm ]
Post subject:  Re: rear wheel bearing
the pic is a bit faint (not there at all?)
yeah the bearing sits out a bit i seem to remember
Author:  Damo [ Tue Apr 14, 2009 2:31 pm ]
Oops, pic was a bit big, haad to resize it.
Author:  Scrawny [ Tue Apr 14, 2009 2:33 pm ]
Yeah, pretty sure they sit slightly proud
Author:  Damo [ Tue Apr 14, 2009 2:37 pm ]
I should probably measure the thickness of the bearing and the depth of the housing where the bearing sits. I assume the bearing sits all the way down onto the seat in the bottom of that recess.
Author:  Scrawny [ Tue Apr 14, 2009 2:43 pm ]
Yeah, it should bottom out on that lip.
Author:  Zook_Fan [ Tue Apr 14, 2009 2:46 pm ]
both my rears had this
Author:  Damo [ Tue Apr 14, 2009 4:42 pm ]
Made some measurements.
The depth of the recess in the housing is 14mm, width of the bearing is 17mm, so the outer edge of the bearing should side proud of the flange by 3mm.
Author:  joeblow [ Tue Apr 14, 2009 5:25 pm ]
yes thats normal damo. had some more plates cut ans will be in the mail this week.
Author:  Damo [ Tue Apr 14, 2009 5:29 pm ]
Was having kittens, though I had a stuffed housing or something!!!
Thanks Joe, should be able to get this baby back together soon!
Author:  lump_a_charcoal [ Tue Apr 14, 2009 9:17 pm ]
Just get a big hammer and wail on it until it is flush!
Author:  brendan [ Tue Apr 14, 2009 9:22 pm ]
BFH fixes eveything :D
Author:  Damo [ Tue Apr 14, 2009 11:26 pm ]
Well that's what I was going to do, but it's lucky i didnt huh :wink:
