It is currently Thu Oct 15, 2026 2:44 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: 03 GV
Post Posted: Mon Apr 28, 2014 7:16 pm
I have an 03 GV i want to lift...
So far I have bought:
30mm F+R king springs
http://www.ebay.com.au/itm/SUZUKI-GRAND-VITARA-2-5L-V6-SQ-LWB-F-R-30mm-RAISED-COIL-KING-SPRINGS-/150747758584?pt=AU_Car_Parts_Accessories&hash=item2319443ff8&_uhb=1
50mm Coil and Strut Spacers
http://www.ebay.com.au/itm/2-Lift-Kit-99-05-Geo-Tracker-Suzuki-Vitara-BILLET-Coil-Spacer-W-Bumpstop-/261244105405?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AGrand%20Vitara&hash=item3cd35cb2bd&_uhb=1
Camber Bolts
http://www.ebay.com.au/itm/J-Power-FRON ... ef4&_uhb=1
With the above components I should gain about 80mm, which I'm assuming won't be good for my CV's
So next on the shopping list would be a diff drop?
http://www.jimnybits.co.uk/shop/grand-vitara/suspension/grand-vitara-front-axle-drop-brackets/prod_95.html
And perhaps a panhard relocater?
http://www.outdoorauto4x4.com/p/813653/grand-vitara-panhard-relocation-bracket.html
Is there anything I've missed that might keep me out of trouble?
I was thinking about getting some Camira rear shocks too.
Would the stockers be able to handle a 3 inch lift?
Sorry for the noob questions but I am one after all :)
Post Posted: Mon Apr 28, 2014 7:36 pm
You better start collecting CV's.
I have a very similar setup.
Front.
40mm king coils
20mm spacers
Dobinson struts
Extended bumpstops (20mm)
Cam bolts
Diff drop brackets
Manual hubs
Vitara 4.8 R&P in GV steel Diff
1510 lockright
Rear.
40mm Dobinson Coils
40mm spacers
Pajero shocks (Munroe)
40mm bump stop spacers
Panhard relocation bracket
Vitara 4.8 diff center
Ive had to make a few things myself as they were not readily available when I originally set it up.
I wouldn't worry about the strut spacers as the CVs will reach their maximum angle on down travel without them (even with the diff drop brackets.)
What size tyres are you planning to run?
Vehicle: 2004GV + bar + custom mods
Post Posted: Tue Apr 29, 2014 8:55 am
might need extended brake lines ?
Post Posted: Tue Apr 29, 2014 4:31 pm
Yes.... definitely
Vehicle: Jeep
Post Posted: Tue Apr 29, 2014 6:01 pm
Can i ask why you wanted 80mm lift ? :D
Post Posted: Tue Apr 29, 2014 6:54 pm
I know why I do...... but ill save that for later
Vehicle: 03 GV
Post Posted: Wed Apr 30, 2014 5:26 pm
Built4thrashing wrote:
Yes.... definitely
Oh yeah! Forgot about the brakes. Where'd you get your extended lines?
Vehicle: 03 GV
Post Posted: Wed Apr 30, 2014 5:36 pm
Yeah, i would prefer not to use them. Sure they won't top out with the extra 80mm?
I'd like to be able to fit 31s or 32s... It has 29s on now.
Vehicle: 03 GV
Post Posted: Wed Apr 30, 2014 5:48 pm
[quote="MacDaddy"]Can i ask why you wanted 80mm lift ? :D[/quote
So i can crush commodores with the huge bad ass 37s im going to put on it...
Haha... I just want more clearance and to be able to fit some decent sized tyres.
Post Posted: Wed Apr 30, 2014 5:56 pm
Be prepaired to spend a lot of time getting them to fit and even more time repairing broken Cv's. Trus me I know.
I run Dobinson lifted struts and without strut spacers the cvs are extremely close to their maximum angle. As to is the lower ball joint.
A CV is strongest when it is straight and weakest at full angle.
I've experimented with strut spacers and I could get the outer cv's to bind up before I had full droop with the wheels dead straight...... Thankfully this was discovered in the garage not out wheeling.
As for extended brake lines.... you only need the rear and any decent brake shop should be able to make and fit one for you.
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Wed Apr 30, 2014 6:09 pm
The front brake lines are pretty tight with 4in
Vehicle: 03 GV
Post Posted: Wed Apr 30, 2014 7:07 pm
Oh sh*t! I want to avoid that... Was that with the dobinson struts? and with or without diff drop brackets?
Post Posted: Wed Apr 30, 2014 7:19 pm
Dobinson strut with diff drops....... front end just runs out of down travel and strut spacers are just not needed.
Vehicle: 03 GV
Post Posted: Wed Apr 30, 2014 8:24 pm
I see, well ill see how i go with the stock struts and no spacers then. Thanks heaps for the info and taking the time to help me out.
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 6:23 pm
So, I put in my 30mm king springs on the weekend. Woohoo! Also had a crack at putting in the coil spacers... I tried the front first, detached the sway bar, calipers, tie rods and struts but there was no way in hell I could get the springs in there. Do you guys reckon I might be able to get the springs and spacers in if I disconnected the diff from the chassis so the CV's can drop down, allowing the control arm to droop down more?
Post Posted: Mon May 12, 2014 6:27 pm
What size spacers do you have for the front?
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 6:34 pm
50mm spacers, with 30mm coils.... Too much maybe?
Vehicle: 99 Grand Vitara
Post Posted: Mon May 12, 2014 6:40 pm
Get some spring compressors. I have to use them to get my 3" springs in, well I had to the first time I put them in.
http://www.strictly4x4.com.au
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 6:42 pm
Another thing too. After fitting the springs I have crazy positive camber in the front. The top strut holes already had camber bolts in, should I put some in the bottom holes as well?
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 6:43 pm
I used spring compressors :?
Post Posted: Mon May 12, 2014 6:52 pm
3in coils and 1in spacer is possible but very much a bitch!! And say good bye to camber and castor. And by 1in space I mean an actual thickness or half an inch so if its an actual 50mm thick spacer it will only fit in the rear no chance getting that in the front! And you can put camber bolts in the bottom as well but it will do bugga all and you will always have neg camber not positive.
Post Posted: Mon May 12, 2014 6:55 pm
I was going to say the same thing - If the front spacer is physically 50mm in height, that's going equal 80mm or so of lift at the wheel. Golly.
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 7:02 pm
Yeah it is a 50mm spacer... Ah dammit, back to the drawing board!
Vehicle: 03 GV
Post Posted: Mon May 12, 2014 7:17 pm
Ahhhhh, so a half inch thickness spacer will actually equate to one inch of lift?
Negative camber? you sure?
Post Posted: Mon May 12, 2014 7:22 pm
The ratio isn't quite 2:1, but it's close.
I'm aware of two camber bolts being used to get excessive lift into alignment. The real answer is less lift. If you have to run two camber bolts to get alignment in spec, the CV's are in pain at ride height, you'll have almost no droop, and the car will ride terribly.
Low is the new lift.
Vehicle: Which one?
Post Posted: Mon May 12, 2014 7:31 pm
Coming soon to a sig near you.
Post Posted: Mon May 12, 2014 7:43 pm
Been done.. long ago :D
Post Posted: Mon May 12, 2014 8:12 pm
I ran king springs my 94 vitara for awhile. I than put spacers in as well. 30mm in the rear and 15mm in the front and I found it was way to stiff it wasn't nice to drive at all so literally a week later I pulled it out and 30mm spacers with the standard springs in the front and ran the king springs in the back with the 15mm spacers it did sit a little high in the front but rode so much nicer than having the kings with spacers. it was also a bitch to get the 30mm spacer in the front with the standard coil.
Vehicle: 03 GV
Post Posted: Tue May 13, 2014 6:16 pm
Ok thanks for the info everyone. I think ill cut my spacers in half and try again when my diff drop brackets are in.
Post Posted: Tue May 13, 2014 8:44 pm
Whoever is selling 50mm front spacers for a gv should be shot! 8O
Users browsing this forum: No registered users and 1015 guests
