It is currently Mon Nov 30, 2026 7:50 pm
Vehicle: sj80 w/myside2. 99GV 2.5V6
Post Posted: Wed Apr 30, 2014 12:34 pm
Anyone put a 1520-LR Lockright into their GV?
I just received mine and expected there to be couplers in the box, however there are none?
Does anyone know if there should be any in there?
Post Posted: Wed Apr 30, 2014 4:17 pm
Pic?
Some just use your factory side gear.
Post Posted: Wed Apr 30, 2014 9:50 pm
OK I should reword that, I was expecting a coupler setup, instead yes it's one that has cutouts for the side gears. I was hoping someone knows if this is the correct set for the GV first gen?
I'm just not sure wheather they sent me the correct lock right as it looks like the box has been opened and resealed.
I'll get some pics up tomorrow
Post Posted: Thu May 01, 2014 5:14 am
I don't know about the GV but 1520 does fit LJ80 Stockman and 1 litre Sierra. They are hard to get these days and will be easy to sell on if it's wrong for your GV.
Post Posted: Thu May 01, 2014 7:00 am
umm I would almost guess the 1520 LR will fit into the front of the GV with the silly 2 pin air actuated front disconnect
From memory, the front centre internals are smaller then 1.3L sierra, so 1.0L internals would make sense.
I think you will want the 1512 or 1532 (couplers) which are the vitara rear autolockers
Post Posted: Thu May 01, 2014 8:09 am
It's for the rear, the powertrax application guide shows the 1520-lr as the rear locker.
I just don't want to pull my diff apart only for the locker not to fit, have to put it all back together only to be pulled apart again once the part issue is corrected.
God help if it happened to someone who doesn't have a heap of mech knowledge and paid someone to install it, only for it not to fit.
While I'm going to do it myself, i'll still be pi$$ed.
also there are a few of 1520-lr's on ebay at the moment, which is where I got mine from
http://www.ebay.com.au/sch/i.html?_trks ... &_from=R40
Post Posted: Thu May 01, 2014 2:20 pm
Pics as promised
Post Posted: Thu May 01, 2014 4:44 pm
Whats the measurement across the locking plates.... external dimensions....
Post Posted: Sun May 04, 2014 2:58 pm
any luck?
Post Posted: Mon May 05, 2014 12:01 pm
External dimensions of the locking plate is 63mm in diameter
jdk81 wrote:
any luck?
This weekend was wheeling at Five Rocks/Stockyard Point so haven't gone for install yet, waiting on new gearbox mount and rear main to arrive.
Will be doing new:
Rear main Seal
Heavy Duty Clutch
Gearbox Mount
Rear lockright (hopefully if it fits)
all at once, as well as new tie rods.
Now on to other issues that arose over the weekend, the dreaded 4WD light. Pretty sure its the pump as there was some water crossings and it quit a short time after a deeper one.
Initially the pump wasn't engaging I could only hear the relay in the 4WD controller clicking over, after looking quickly at it and shaking some water out of the connector It started working and it sounds different than it use to, so ended up coming home 2WD only. Then after airing back up, after the pump had some time to dry out decided to give it another shot and bang 4WD, dam thing.
Going to diagnose the system and take it apart following fordems tut etc later however I dropped by the wreckers I know has a GV in the yard this morning. Found the air pump and scored it for $33
don't know if it works as yet but for the money makes for good spares. Also going to be moving it to higher ground
Post Posted: Wed May 07, 2014 12:58 pm
I did some measuring for you with the junk diffs i have.
The internal dimensions of a GV diff (4.3 ratio) is approx 76mm internal, and the side gears are 75mm
vit fronts/sierra fronts/Sierra rear side gears are all 70mm
I can not find a GV front diff centre with the air actuated collar, I probably binned them a while ago.
Vehicle: 2004GV + bar + custom mods
Post Posted: Wed May 07, 2014 1:54 pm
Make sure your 4wd pump pipes are clean too. Dust, water etc. can be killers.
If you look hard enough in google, someone posted a complete rebuild of the 4wd pump - his had the rubber membrane broken.
Also, 33$ ? SCORE. When I had pump issues, the mechanic quoted 600$ new, at least 350 from a wreckers. (I walked away)
Post Posted: Thu May 08, 2014 7:58 am
Hmm now you have me a little concerned, why would my locking plates only be 63mm diameter
Post Posted: Thu May 08, 2014 5:59 pm
All 1.3 Sierra / Vit / X90 / GV diffs all have the same size side gears except the Air operated GV front. These are smaller. The 1520 would have smaller locking plates so they can fit inside the air operated diff center.
The 1510 and 1512 lock rights will not fit in an air operated diff...... Ive tried.
Post Posted: Fri May 09, 2014 4:38 am
I think the length of the cross shafts would be the best indicator?
Post Posted: Fri May 09, 2014 7:29 am
length of the full shaft is 100mm
Post Posted: Sat May 10, 2014 2:29 pm
More measuring
Length of full shafts in GV rear and vit front/sierra front/rear = 100mm
Vit front long shafts dont have the oil grooves cutout, they have small flat sections machined out to allow oil in, these would be less prone to cracking.
GV rear pins are not held in by rolled pins, as the 4.3 ring gear has extra material on the inside to hold the pins in place.
GV rear side gear is 75mm diam, and will not fit with correct spider gears in a vit/sierra centre.
It will not fit with an auto locker in it.
Sierra rear 26 spline on top, GV rear 26 spline bottom.
EDIT: getting pic to work
Post Posted: Sat May 10, 2014 7:06 pm
But a sierra lockright (1510/1512) will fit in the rear of a Gv and Vit with out the need to swap the side gears.
Id never compared the rear GV side gears to a Vit or sierra with calipers...
Post Posted: Sat May 10, 2014 11:26 pm
It was more to see if the side gears from the gv could be used as 26 spline side gears in front diffs.
But whilst they drop in, they wont fit with a locker or spider gears etc.
Post Posted: Sun May 11, 2014 8:17 am
Thanks for the pics and info, I guess I'll have to wait till my diffs come out.
Post Posted: Sun May 11, 2014 8:51 am
That would be due to their height.....
Post Posted: Sun May 11, 2014 1:50 pm
Well due to the geometry an increase in diam, means an increase in height.
I was hoping they would be a bit shallower to allow them to sit at the same depth.
Users browsing this forum: Google [Bot] and 248 guests
