It is currently Sun Oct 11, 2026 7:38 am
Vehicle: sj80 w/myside2. 99GV 2.5V6
Post Posted: Wed May 14, 2014 9:18 am
Anyone use these or even heard of them?
seems like a good idea
http://www.ebay.com.au/itm/Tire-Balanci ... 1065257782
Post Posted: Wed May 14, 2014 12:56 pm
There was a discussion on this a few years back. Most truck tyres use them (at least on the steer axles) but I'm not sure how good they'd be for a road car/small 4wd tyre. Give it a go and let us know
Post Posted: Wed May 14, 2014 2:03 pm
all the sales "crap" state that even motorbikes and scooters benefit from them.
For ~$60 I think I'll give them a go
Vehicle: 1997 Sierra SJ80
Post Posted: Wed May 14, 2014 3:26 pm
Rema Tip top sell them.
Remember, you only need about 50 grams maximum per tyre. In a zook, prolly 40 grams would be enough.
And if you get them wet, they wont work very well.
Vehicle: X-90 + Lwb Sierra + DeVitt +++
Post Posted: Wed May 14, 2014 4:15 pm
they can get stuck in the Valve when Airing down apparently .
Post Posted: Wed May 14, 2014 5:03 pm
yeah, but you can buy filtered valve cores. In fact you should use them, regardless if you let yer tyres down or not.
Post Posted: Wed May 14, 2014 5:07 pm
Why can't you just get the wheels balanced by a shop?
Post Posted: Wed May 14, 2014 5:19 pm
I'll add some input here.
When I bought my walker evans wheels, the previous owner was running auto balance powder/beads in the 37 12.5 Creepy Krawlers he had on the rims.
In an off road situation with low tyre pressure, the inner bead can (and does) lift off the tyre from time to time. In extreme cases, this can lead to a burp, but not always. this partial unseating can result in powder/beads getting trapped under the inner bead. In the case of my walkers, it was virtually impossible to unseat the inner bead as the powder formed a wedge between the tyre and wheel that jammed the tyre on.
He's not running it on his new rims/tyres as a result. He tried about 6 different tyre shops before he found someone who could break the bead.
Post Posted: Thu May 15, 2014 8:54 am
These are supposed to actively balance the tyres when driving, so adjust for wear, lost weights, anything etc.
And from that glowing review, I'll stay away from them and not even poke at them with a 50ft clown pole
Post Posted: Thu May 15, 2014 9:29 am
wear shouldn't unbalance a tyre, cos its spinning, so the wear would be self balancing in itself. Lost weights are a chance at happening, but i've only ever lost a weight once - and it was because i smashed it off on some rocks (actually, i bent it off). But even still it was only a 20g weight. Didnt even notice it missing on the road but had it replaced anyway.
If its about aesthetics - i paint my wheel weights black to match my rims and you hardly notice they're there.
Post Posted: Thu May 15, 2014 9:33 am
It's almost impossible to keep clip on wheel weights in place in Vic.
Steve
Post Posted: Thu May 15, 2014 10:49 am
Can you use the stick on ones instead?
I ran the stick-on ones when i had simex's cos they were so out of balance... needed 300g in one spot, so piled up a bunch of the stick on weights and they never budged.
Post Posted: Thu May 15, 2014 11:26 am
I run balance beads in all my truck tyres, it is great in truck/light truck tyres and likely 4x4 tyres tyres. anything that requires a lot of weights to balance.
as for tyre removal we have never had an issue, but steve has told me before about his crawler and alloy beadlock issues,this could possibly be due to very low pressures and perhaps alloy corrosion inside the wheel too.
I cant really see any point in using it in car type radials or motorcycle tyres as the rarely need much weight and the tyres are generally much better made/balanced from new
Vehicle: sj51
Post Posted: Thu May 15, 2014 2:37 pm
I ran golf balls in my old steel beadlocks, it worked better than nothing..
they were only in for a few thousand kms.. they came out smooth..
From what I have read they can cause damage to the inside of the tyre after awhile..
but for my old bush wheels they got me to the tracks just fine
Post Posted: Thu May 15, 2014 9:51 pm
Just wondering... wouldn't water or Slime achieve the same thing?
Post Posted: Fri May 16, 2014 11:01 pm
Water gets wOoObBlY at speed.
Post Posted: Tue May 20, 2014 5:19 pm
Steve how big were the balls? i have herd nothing but good things up till now! i'm going to run them in my swampers as there hard to balacne with the sikaflex round the beads.
Post Posted: Tue May 20, 2014 7:41 pm
I don't know how big the balls were. All I saw was the mess they made.
I don't know why you'd try to balance swampers.
Users browsing this forum: Google [Bot] and 266 guests
