It is currently Mon Sep 28, 2026 5:12 pm
Post Posted: Sun Apr 19, 2009 1:40 am
hey people. just wondering when removing leaves do you remove the loader leaf or leave it alone & start with the other ones. also when using commo shocks in the front should you use bump stop ext. if so what size. i was thinking about 25mm.
any advice would be great. :?
also considering hiace shocks in rear either gabriel or monroe cause there cheaper. :wink:
Post Posted: Sun Apr 19, 2009 1:46 am
Start with the load leaf (big bottom one) that will give you much better flex. The Commo/Hilux shocks need bumpstop spacers from what I've heard, at least 25mm
Users browsing this forum: Google [Bot] and 96 guests
