Wasnt I talking to you about it the other day, when you were over?
From looking at it, need to either swap the coolant temp sensor, and throttle body sensor, or swap the whole lot over. I think the bolt pattern for the throttle body is the same.
Then plug up the pressure sensor. Baleno doesnt have egr, so can add the vit egr plug to keep the plug happy (in case it causes some problems). Need to use the baleno thermo stat housing and temp sensor etc.
Would have to modify the vit loom a little as the sensors etc are in different spots.
The throttle cable and kickdown brackets are a little different too.
If my bonnet doest fit, I think I will be trying it
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
Posted: Wed May 14, 2014 8:56 pm
Yeah, we had a brief chat about it. It got me thinking about it more. was hoping someone might have done it.. here's to your bonnet not fitting then you can drip feed me the info..
Users browsing this forum: No registered users and 295 guests
