| intake swap http://auszookers.com/forum/viewtopic.php?f=5&t=46250 |
| Author: | pezz [ Wed May 14, 2014 7:21 pm ] |
| Post subject: | intake swap |
Just wondering if anyone has swaped a vit efi intake out and fitted a baleno unit? Did any wiring or plumbing need to be altered? |
| Author: | jdk81 [ Wed May 14, 2014 8:49 pm ] |
| Post subject: | Re: intake swap |
Wasnt I talking to you about it the other day, when you were over? From looking at it, need to either swap the coolant temp sensor, and throttle body sensor, or swap the whole lot over. I think the bolt pattern for the throttle body is the same. Then plug up the pressure sensor. Baleno doesnt have egr, so can add the vit egr plug to keep the plug happy (in case it causes some problems). Need to use the baleno thermo stat housing and temp sensor etc. Would have to modify the vit loom a little as the sensors etc are in different spots. The throttle cable and kickdown brackets are a little different too. If my bonnet doest fit, I think I will be trying it |
| Author: | pezz [ Wed May 14, 2014 8:56 pm ] |
Yeah, we had a brief chat about it. It got me thinking about it more. was hoping someone might have done it.. here's to your bonnet not fitting |
