| tailshaft http://auszookers.com/forum/viewtopic.php?f=5&t=4627 |
| Author: | ajsr [ Sat Apr 18, 2009 10:04 pm ] |
| Post subject: | tailshaft |
hey all the problem I have a coily rear diff center with a airlocker, its going into a narrow track.The problem is the the flange on the coily diff is the same as wt different pattern to narrow track. The question Will a wt diff end of a tail shaft mate to the upper end of a narrow track transfer end??? If so anyone in se melb want to part with a wt rear tailshaft? The other opion is fitting a wt diff flange to the nt shaft, do these fit?Is it the same uni joint between the two? cheers andrew |
| Author: | Mike [ Sat Apr 18, 2009 10:52 pm ] |
| Post subject: | Re: tailshaft |
yes you can use half a WT and half a NT shaft and thats the easiest way to do it |
| Author: | royce [ Sun Apr 19, 2009 1:12 am ] |
no dont do this, tailshafts are built as a single balanced unit, go swapping bits round it'll muck it up better to fit a NT flange to the diff or shaft, same uni so it will fit |
