It is currently Tue Jul 28, 2026 12:32 am
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Sat May 17, 2014 3:03 pm
did a search, couldnt find anything similar to the possible issue i have
now, installed a rear diff, all new bearings, tensions and backlash all set correctly, locker was a relatively tight fit, no hammers or anything crazy needed though
now, my issue is i have a small amount of "free play" in the axle area, so when i lift both wheels off the ground, or even one of either side, theres a bit of free movement before it catches the locker and starts to move the shaft and other wheel/unlock the other wheel.
basically look at the wheel as a clock, i can move from 12 to 1 and back freely. im assuming its between the locker and the side gear.
anyone else seen this before?
cheers, cal
Vehicle: WT sierra, GU CRD
Post Posted: Sat May 17, 2014 3:06 pm
cheers, cal
They do have some slack in them.
I have to give mine a bit of a shove before it will lock them both together.
I love ZD30. :)
Post Posted: Sun May 18, 2014 6:43 am
Normal
Post Posted: Sun May 18, 2014 11:54 am
http://youtu.be/Ns2RaGLIUGQ
I made a small video, its like it has a small ammount of movement in the side gears
Post Posted: Sun May 18, 2014 5:09 pm
Yeah thats normal. Its the locker going from forward drive side to the reverse drive side of its operation.
Post Posted: Sun May 18, 2014 5:33 pm
Aah sweet. Seemed a bit strange when i could turn the driveshaft when i got under as if its backlash was out. Needed an oil change anywho so thats all good to do now
Post Posted: Sun May 18, 2014 5:41 pm
You can feel the back lash by lightly rocking the shaft back and forth.
It's a just an auto locker thing. They're rough.
I like them though, cheap and simple.
Post Posted: Sun May 18, 2014 5:48 pm
Yea thats what i liked, at first i wasnt sure about it as it was harsh, but now its bedded in a bit, its quiet easy going with an occasional bind up. Just have to drive to the conditions. Ill keep my wrx as the speed machine haha
Users browsing this forum: No registered users and 490 guests
