It is currently Mon Sep 28, 2026 4:25 pm
Post Posted: Sat Apr 18, 2009 10:04 pm
hey all
the problem
I have a coily rear diff center with a airlocker, its going into a narrow track.The problem is the the flange on the coily diff is the same as wt different pattern to narrow track.
The question
Will a wt diff end of a tail shaft mate to the upper end of a narrow track transfer end???
If so anyone in se melb want to part with a wt rear tailshaft?
The other opion is fitting a wt diff flange to the nt shaft, do these fit?Is it the same uni joint between the two?
cheers andrew
lesspostingmorewheeling
Post Posted: Sat Apr 18, 2009 10:52 pm
yes you can use half a WT and half a NT shaft and thats the easiest way to do it
Post Posted: Sun Apr 19, 2009 1:12 am
no dont do this, tailshafts are built as a single balanced unit, go swapping bits round it'll muck it up
better to fit a NT flange to the diff or shaft, same uni so it will fit
Users browsing this forum: No registered users and 114 guests
