It is currently Tue Oct 13, 2026 6:04 am
Vehicle: 92 Sierra hardtop
Post Posted: Fri May 23, 2014 6:39 pm
Hey guys from what I've read I haven't got a sure answer haha. So does a jimny pump and box bolt straight up to a stock 1.3 Sierra engine. ( what model jimny, g13bb or m13a??) do I need a jimny pitman or will the sierra one work. Also is a jimny pump a v belt? And does the steering shaft work or will it be right?? Thanks guys :D :D
Vehicle: sj51
Post Posted: Fri May 23, 2014 6:45 pm
Box bolts straight on, stock column used but shortened a bit,
use them jim ptiman arm and ditch your steering dampener,
not sure about the pump mount, imagine one of a g13bb would fit.
multi rib pullys for the win
Post Posted: Fri May 23, 2014 6:53 pm
Ok sweet, so jims are multi rib not v rib??
Vehicle: sj51
Post Posted: Fri May 23, 2014 7:02 pm
The jim pump I bought from the uk was,
even if its not I would convert to multi rib,
its also a good opertunity to do a falcon alt swap
Post Posted: Fri May 23, 2014 7:10 pm
Yea true !
Users browsing this forum: No registered users and 229 guests
