| Jimny power steer on a sj70 Sierra?? http://auszookers.com/forum/viewtopic.php?f=5&t=46369 |
| Author: | Abouwer123 [ Fri May 23, 2014 6:39 pm ] |
| Post subject: | Jimny power steer on a sj70 Sierra?? |
Hey guys from what I've read I haven't got a sure answer haha. So does a jimny pump and box bolt straight up to a stock 1.3 Sierra engine. ( what model jimny, g13bb or m13a??) do I need a jimny pitman or will the sierra one work. Also is a jimny pump a v belt? And does the steering shaft work or will it be right?? Thanks guys |
| Author: | pezz [ Fri May 23, 2014 6:45 pm ] |
| Post subject: | Re: Jimny power steer on a sj70 Sierra?? |
Box bolts straight on, stock column used but shortened a bit, use them jim ptiman arm and ditch your steering dampener, not sure about the pump mount, imagine one of a g13bb would fit. multi rib pullys for the win |
| Author: | Abouwer123 [ Fri May 23, 2014 6:53 pm ] |
Ok sweet, so jims are multi rib not v rib?? |
| Author: | pezz [ Fri May 23, 2014 7:02 pm ] |
The jim pump I bought from the uk was, even if its not I would convert to multi rib, its also a good opertunity to do a falcon alt swap |
| Author: | Abouwer123 [ Fri May 23, 2014 7:10 pm ] |
Yea true ! |
