It is currently Thu Oct 15, 2026 4:25 am
Post Posted: Thu May 29, 2014 5:12 pm
Hey All!
Had Rego tell me I have too much play in the front wheels on my '90 Vitara.
This is after I had the wheels bearings replaced, cleaned everything and re-greased. Went from tapered roller bearings to ball bearings (cylindrical in shape).
Is there anything else that I should be looking at that might be causing this issue, before I throw in the towel and go to a mechanic?
Post Posted: Thu May 29, 2014 5:24 pm
wheel bearings all torqued to spec, also could be worn hubs?
Post Posted: Thu May 29, 2014 5:36 pm
Play at wheels, or play at steering wheel?
Look at your idler arm/bush (opposite end to the steering box)
Post Posted: Thu May 29, 2014 5:49 pm
It's got play at the wheels. Steering appears fine.
Post Posted: Thu May 29, 2014 5:55 pm
Looks like the original hubs, but didn't think they were looking dodgy. Maybe it would be worth replacing them also. Depends on the cost of new ones though.
Would the ball joint on the knuckle cause play issues?
Post Posted: Thu May 29, 2014 6:01 pm
everything from the pitman arm to wheel bearings & everything in between can cause play. surely if the rego checks are that thorough they'd be able to tell you where the problem is?
i guess that's one of the good things about living in SA, no rego inspections.
Post Posted: Thu May 29, 2014 6:32 pm
I guess that's one of the good things about living in SA, no rego inspections.
Yeah I asked them if they had an idea. The inspector said he wouldn't know without pulling it apart. Not sure my perils were of much concern.
SA sounds like the bees knees! Can we adopt your laws please?
Users browsing this forum: No registered users and 1132 guests
