Joined: Sun Sep 23, 2012 5:19 pm Posts: 47 Location: brisbane
Vehicle: 92 Sierra bars F&R locked
Posted: Thu May 29, 2014 5:37 pm
has anyone ever snapped off the pin in their sierra transfer case that the speedo cable spins off? if so how do you fix it? do you have to pull the transfer case out?
Posted: Fri May 30, 2014 8:03 pm
Sourced the part. The whole collar acutally slips out when you take the bolt completely out of where the speedo cable bolts in. And the speedo gear slips in behind that. Luckily its an easy change bit it Costs around $70 for a new gear.
Vehicle: 91 sierra wt
Posted: Sun Jun 01, 2014 12:04 pm
Ah cheers had a play with it today don't think that's my problem!
I think it may be my speedo I accidentally broke the tabs on the top when I removed it last time so I don't think the cable is seating properly in the speedo when I wiggle it into to place it works kind of for a few moments
Users browsing this forum: Google [Bot] and 117 guests
