http://auszookers.com/forum/
Avm hubs
http://auszookers.com/forum/viewtopic.php?f=5&t=46449
Author:  jonno_racing [ Fri May 30, 2014 2:15 pm ]
Post subject:  Avm hubs
So it turns out I have plenty of asian hub parts but no actual complete hubs.
I do have a set of avm hubs. There missing a few bolts but no biggie.
Are they any good at all? (Running 34s locker and good gearing)?
Author:  Zook_Fan [ Fri May 30, 2014 2:27 pm ]
Post subject:  Re: Avm hubs
I ran AVM's with 31 Extreme's, 6.5's and air locked front. Never had an issue with them at all with comp use as well.
I like the internals of them far better than the aisin spring set up
Author:  SierraDan [ Fri May 30, 2014 3:39 pm ]
I had some for a bit. They worked. Just hated the little screws that hold the locking cap on.
Author:  jonno_racing [ Fri May 30, 2014 8:07 pm ]
Cheers guys. I will clean up and run them!
Author:  buzbox [ Fri May 30, 2014 9:05 pm ]
I had the sealed AVM hubs on my Vit, they were fine. Not being fully serviceable, one got some crap inside and started making horrible noises so I bought the shiny fancy ones. Broke them on it's first outing. I wasn't even doing anything difficult. Sent them back under warranty, had them fixed, Sold them.
Author:  fordem [ Fri May 30, 2014 10:25 pm ]
What broke?
As far as I know AVM is a Brazilian OEM for several other brands - Mile Marker, Rugged Ridge & SuperWinch come to mind - and they are also used by several vehicle manufacturers as OE - I've had no problems with mine (and yes, I do have the "shiny" ones).
Author:  buzbox [ Fri May 30, 2014 10:33 pm ]
Not sure exactly, there was just a note saying, Fixed, tested ok.
I wasn't too impressed, but at least the after sales service from the peope i bought them off was good.
Author:  MrRocky [ Sat May 31, 2014 4:24 pm ]
The single piece ones are very good i ran them for years. Ive seen a few patrols with the 2 piece ones stuff up snd the allen key bolts snap onsaid 2 pice ones also
Author:  jonno_racing [ Mon Jun 02, 2014 12:00 pm ]
So I have mine off and soaking in some degreeser. There off a zook on 31s so I figure they must be ok.
What a pain to get off. Started with a allan key. Then torx bit tapped in then had to dill some + half of the bolts were missing to start with!
I have a pretty good idea how to fix this (will post up latter if it works.)
What's peoples opinions on hib bolts?
Should I ho grade 12 shcs from the start or go cheepies and replace track side?
