It is currently Tue Oct 20, 2026 11:25 am
Vehicle: G16b 83
Post Posted: Mon Jun 02, 2014 7:02 pm
Has anyone had trouble getting a 99 jimny gearbox off an engine (g13bb) I've checked 10 times that all the bolts are un done
Post Posted: Mon Jun 02, 2014 7:04 pm
Sideways wiggle? Pry bar between gearbox and bellhousing?
Post Posted: Mon Jun 02, 2014 7:08 pm
Take starter motor off
Vehicle: G16b 83
Post Posted: Mon Jun 02, 2014 7:16 pm
Yer starter is off have done a lot of prying and wriggling
Post Posted: Mon Jun 02, 2014 7:17 pm
Is it loose around the bellhousing or still tight?
Vehicle: G16b 83
Post Posted: Mon Jun 02, 2014 7:21 pm
Yer it's moved 25 to 30 mill but won't go any further the engine and box is out of the car
Post Posted: Mon Jun 02, 2014 7:22 pm
Even gap all around?
Post Posted: Mon Jun 02, 2014 7:24 pm
Spigot bearing or spline must be grabbing. If you can get a pry bar on both sides then try giving it a bit of extra persuasion
Are you taking the weight of the box so it can be pulled straight back?
Vehicle: G16b 83
Post Posted: Mon Jun 02, 2014 7:57 pm
Yer even gap all round I've sprayed a shitload of wd onto the spline and will let it sit and try tomorrow after work
Users browsing this forum: No registered users and 326 guests
