http://auszookers.com/forum/
3" down to 2"
http://auszookers.com/forum/viewtopic.php?f=5&t=46504
Author:  Jrd [ Mon Jun 02, 2014 8:01 pm ]
Post subject:  3" down to 2"
Hi Guys,
If a Jimny already has the full 3' TG lift, can you get away with replacing just the coils to bring it back to 2'? Would the adjustable panhard, castor correction, shaft spacer, shocks etc work?
Author:  zukenutter [ Mon Jun 02, 2014 8:09 pm ]
Post subject:  Re: 3" down to 2"
I don't know specs of TG Lift but mostly it'll be ok. The shaft spacer will probably need to come out and shocks will probably be too long which could cause your coils to fall out when off-road. The adjustable panhards will need to be slightly readjusted.
Author:  Jezza86 [ Tue Jun 03, 2014 7:07 am ]
if you install some spring retainers you can get by without replacing the shocks.
too much castor correction can cause wobble problems. if you only have castor bushes you might be ok.
remove the front prop spacer
Author:  Jrd [ Thu Jun 05, 2014 10:08 am ]
thanks guys
