It is currently Thu Jul 30, 2026 11:29 am
Vehicle: sierra sj70 1993
Post Posted: Thu Jun 05, 2014 5:51 pm
what needs to be done on 1.6 conversion into sierra is there any links to someone that has already done one?
Post Posted: Thu Jun 05, 2014 7:37 pm
They're plenty of people who have done this conversion, I for one. My advise would be to purchase BenT's kit it will include everything you need plus instructions (Minus motor etc.).
viewtopic.php?f=15&t=15009
Here's the search area if you'd like to look yourself
search.php
The hardest part of the conversion will be swapping your oil pick up off your current g13 onto the g16a plus you may need to 'massage' your g13 sump to fit onto the g16a with it's new pick-up
It's a very simple conversion with minor headaches, here are a few items that you will run into
Starter motor body may need grinding down to fit
Clutch cable will need spacing
The motor will sit higher so either spacing of the bonnet or body-lift
Air intake will be on opposite side if you use the g16a carby+intake
I hope this helps with your conversion and if I've forgotten anything please add to it:)
Good luck with your conversion!
Post Posted: Fri Jun 06, 2014 4:34 am
How is the pick up swapped and by 'massage' what do you mean
Post Posted: Fri Jun 06, 2014 4:36 am
I whsnt to be abe to do this in a weekend is there and one in the childers or bundy area able to help?
Post Posted: Fri Jun 06, 2014 9:43 pm
Cut and weld the pick-up and by 'massage' i mean using a hammer on the sump.
Users browsing this forum: No registered users and 319 guests
