| Vitara Power steering Issue http://auszookers.com/forum/viewtopic.php?f=5&t=46542 |
| Author: | Kez187 [ Sat Jun 07, 2014 10:05 am ] |
| Post subject: | Vitara Power steering Issue |
I have a Suzuki Vitara 1996 4 door 2L 6 Clyinder. My steering stiff last week. I thought Power Steering (PS) died. This week it works 40% of the time and the other 60% is stiff. Its not a fan belt. Its not air in Hydraulic fluid. (if it was it would stay dead because not enough pressure from air.) My last service replaced the fluid. - must be in the gear box? Please help if you can. Want to try fixing before sending to a M3CHAN1C $$$ |
| Author: | DarkHorse [ Wed Jun 11, 2014 12:13 am ] |
| Post subject: | Re: Vitara Power steering Issue |
Gearbox? You mean steering box? My money would be on the pump. $$ for fix, or take your chances with a replacement used one... |
| Author: | damagera [ Wed Jun 11, 2014 6:31 pm ] |
M8 i got the same problem SOMETIMES but only when i start it in the mornings SOMETIMES feels as though there is something stopping the steering from turning but then after i move about 20 meters then it frees up no leaks and the fluid seems fine... i was just going to get a 2nd hand pump and see if that works |
