Ok, if I'm swapping from the 1l engine to a 1.3 in my ute should I also swap the diffs. I'm taking engine,gearbox and transfer from a donor car to put in my build, just not sure if the 1 l diffs should also be swapped out or kept and what does it mean for final ratios? Build will run 31's
Users browsing this forum: No registered users and 65 guests
