| Motor swap plus http://auszookers.com/forum/viewtopic.php?f=5&t=46560 |
| Author: | Madhatter [ Mon Jun 09, 2014 5:00 pm ] |
| Post subject: | Motor swap plus |
Ok, if I'm swapping from the 1l engine to a 1.3 in my ute should I also swap the diffs. I'm taking engine,gearbox and transfer from a donor car to put in my build, just not sure if the 1 l diffs should also be swapped out or kept and what does it mean for final ratios? Build will run 31's |
| Author: | vet 180 [ Mon Jun 09, 2014 6:20 pm ] |
| Post subject: | Re: Motor swap plus |
The 1l transfer has better ratios from memory I would keep that |
