http://auszookers.com/forum/
Air tank in cab??
http://auszookers.com/forum/viewtopic.php?f=5&t=46619
Author:  B1GBOAR [ Sat Jun 14, 2014 6:39 pm ]
Post subject:  Air tank in cab??
Hey guys,
Im wondering what your thoughts are on having an air tank behind the front seats? I have it temporarily mounted behind the drivers seat next to my compressor and I like it. Easy to get to, Plum stuff in to ect. Now Ive got a Pressure relief valve on it, A pressure gauge and about to build a blast guard around it so in case of failure it cant make any projectiles of anything. I have no room under the engine bay nor under the Jimny.
Thoughts? I do know its illegal to have a pressure vessel in the cab/ pressure lines. The other point worth mentioning is I only have pressure in the tank when stationary anyway.. :?: :?:
Author:  SierraDan [ Sat Jun 14, 2014 8:16 pm ]
Post subject:  Re: Air tank in cab??
I wouldn't have an issue with the precautions you have.
Author:  B1GBOAR [ Sun Jun 15, 2014 12:39 pm ]
yeh thats what im thinking, Cheers Dan
Author:  alien [ Sun Jun 15, 2014 2:07 pm ]
Sounds pretty safe to me... I assume you're using a proper pressure tank too, not some home made jobby... Something like an old Scuba tank would be safe as houses given they are rated to thousands of PSI.
Author:  Xr6_matt [ Sun Jun 15, 2014 11:34 pm ]
I have an air tank in my cab, it's enclosed, with pressure release valves, and pressure switches connected to the relay, so the compressor won't over fill the tank. I also only use it while stopped, and make sure it's empty before taking off. As others said, I wouldn't have a problem with it.
Author:  B1GBOAR [ Mon Jun 16, 2014 5:53 pm ]
yeh Ive got an ARB 4lt tank rated to 150psi at 90degC My pressure valve is set at 120psi. Sweet cheers!!
:beer:
