It is currently Tue Oct 27, 2026 2:02 pm
Vehicle: Suzuki Jimny SN413 2013
Post Posted: Sat Jun 14, 2014 6:39 pm
Hey guys,
Im wondering what your thoughts are on having an air tank behind the front seats? I have it temporarily mounted behind the drivers seat next to my compressor and I like it. Easy to get to, Plum stuff in to ect. Now Ive got a Pressure relief valve on it, A pressure gauge and about to build a blast guard around it so in case of failure it cant make any projectiles of anything. I have no room under the engine bay nor under the Jimny.
Thoughts? I do know its illegal to have a pressure vessel in the cab/ pressure lines. The other point worth mentioning is I only have pressure in the tank when stationary anyway.. :?: :?:
BRAAAAAAAAARRRBPPpPP
Post Posted: Sat Jun 14, 2014 8:16 pm
I wouldn't have an issue with the precautions you have.
Post Posted: Sun Jun 15, 2014 12:39 pm
yeh thats what im thinking, Cheers Dan
Post Posted: Sun Jun 15, 2014 2:07 pm
Sounds pretty safe to me... I assume you're using a proper pressure tank too, not some home made jobby... Something like an old Scuba tank would be safe as houses given they are rated to thousands of PSI.
Vehicle: Xr6
Post Posted: Sun Jun 15, 2014 11:34 pm
I have an air tank in my cab, it's enclosed, with pressure release valves, and pressure switches connected to the relay, so the compressor won't over fill the tank. I also only use it while stopped, and make sure it's empty before taking off. As others said, I wouldn't have a problem with it.
Post Posted: Mon Jun 16, 2014 5:53 pm
yeh Ive got an ARB 4lt tank rated to 150psi at 90degC My pressure valve is set at 120psi. Sweet cheers!!
:beer:
Users browsing this forum: No registered users and 173 guests
