| vitara a/c http://auszookers.com/forum/viewtopic.php?f=5&t=46699 |
| Author: | redvitara [ Sat Jun 21, 2014 11:27 am ] |
| Post subject: | vitara a/c |
Gday everyone I bought my jlx lwb a couple of years ago & the a/c hasn't worked since then. I eventually chased it down to a wire (yellow with blue stripe) not being connected to a temp? Sender. Does this wire double up on temp gauge sernder or does it go somewhere else? Any help or pictures would be appreciated? Thanks Barry |
| Author: | neofitou [ Sat Jun 21, 2014 3:16 pm ] |
| Post subject: | Re: vitara a/c |
http://www.suzukiinfo.com/ All the manuals you will ever need! |
| Author: | redvitara [ Sat Jun 21, 2014 3:38 pm ] |
Gday Yep, I've been all over that site & all I can find are wiring diagrams. They show that the wire needs to go to a "coolant temperature sender". The only temp sender I can find is for the gauge. I need to find the physical position of this sender if it is not the one for the gauges. Barry |
| Author: | 4x4ewok [ Sat Jun 21, 2014 5:00 pm ] |
In the thermastat housing their should be provision for 2 temp senders. The front one is for the temperature gauge, the rear one is for the a/c. In my car it has a blank in it that you should be able to pull out and replace with the sender. |
