| Speedo problem after WT case conversion http://auszookers.com/forum/viewtopic.php?f=5&t=46749 |
| Author: | MikeyS [ Tue Jun 24, 2014 11:03 pm ] |
| Post subject: | Speedo problem after WT case conversion |
Hi, I have just recently finished my ORA W/T Transfer case conversion in to my 98 jimny and my speedo has stopped working it was working perfect before conversion but now it wont move at all, has anyone else had this problem or do you know how to fix this problem?? Thanks Michael |
| Author: | jimny_timmy [ Wed Jun 25, 2014 4:24 pm ] |
| Post subject: | Re: Speedo problem after WT case conversion |
Didn't forget to plug the sensor back in??? Or blow a fuse? The speedo wire is green from behind the dash. If you undo the 4? Screws holding the cluster in, it'll pop straight out and you should be able to test light/multimeter it. |
| Author: | MikeyS [ Wed Jun 25, 2014 4:33 pm ] |
I plugged the sensor back in definetly, do you have a picture of the fuse? Would help me alot. more of an visual person. |
| Author: | jimny_timmy [ Wed Jun 25, 2014 4:35 pm ] |
My jimny is half hour drive away bit I'm pretty sure there's a speedo fuse with the rest of them (ie radio, lights etc) Does the tacho work? |
| Author: | MikeyS [ Wed Jun 25, 2014 4:42 pm ] |
Tacho? The rev side works. Just not the speedo:l |
| Author: | jimny_timmy [ Wed Jun 25, 2014 4:46 pm ] |
Lol that's the tacho.... If that's working then I'd suggest you look at the sensor and double check it's clean, the wire isn't broken, the pins in the plug haven't been bent or damaged. I'm not overly familiar with the ORA kit, but from what I know the sensor goes onto a bracket? You haven't got the sensor the wrong way round? (I don't know if that's possible or not?) |
| Author: | atari4x4 [ Wed Jun 25, 2014 5:10 pm ] |
tried closing the gap between the sensor & the tone ring? it's probably spaced too far away to pick up a signal. |
| Author: | MikeyS [ Wed Jun 25, 2014 5:24 pm ] |
I left the little rubber ring on because it fits more snug on the mount, ill try taking it off to see if it can get closer thanks yous both ill try and find the fuse also bring the sensor closer. |
| Author: | zukenutter [ Wed Jun 25, 2014 8:11 pm ] |
Maybe share a photo of your speedo ring and sensor |
| Author: | MikeyS [ Wed Jun 25, 2014 8:14 pm ] |
Ill send a pic first thing tomorrow morning when it is light. |
| Author: | cal213 [ Sat Aug 02, 2014 2:48 pm ] |
Any fix on this? I also have the same problem. Starting by first trying to test the sensor. Waiting on a multimeter at the moment. I tried to spin the output by hand and have the ignition on to see if the dial moved to confirm i would have to close the gap. No luck |
| Author: | MikeyS [ Mon Aug 04, 2014 4:03 pm ] |
sorry mate for the late reply but my sensor got hit by the flange bolts need to replace the whole thing |
