It is currently Mon Sep 21, 2026 1:14 pm
Vehicle: Current toyota surf
Post Posted: Thu Jul 24, 2014 5:07 pm
Hey guys in the middle of the g16b conversion and a bit stuck on the wiring side of things. Is there anyone in Perth that I will be able to have a look at their conversion and get some pointers or anyone wiling to lend a small hand would be greatly appreciated I'm located north of the river.
Cheers Dev
Post Posted: Thu Jul 24, 2014 5:55 pm
First thing you'll need is a pin out diagram to suit your ecm.
There is a number stamped on the case.
Post Posted: Thu Jul 24, 2014 7:12 pm
Cheers for the reply forgot to mention the loom that came with the motor had already been cut down with one or two wires needing to be cut which have already been done. Just need to sort out the wires where they go and tape the loom back up again.
Also do you know where the vacuum hose for the brake cylinder is on the 1.6 and heater hose?
Vehicle: zook
Post Posted: Thu Jul 24, 2014 8:27 pm
Brake vacuum line connects from brake booster to the spigot on the side of the inlet manifold, indicated with the red square, if you are using a baleno inlet manifold. It will be in a similar position on a Vit manifold
I am only guessing (I cant remember exactly) on the heater hoses but it will be on the back of the block or head, a pair of spigots the same diameter.
Post Posted: Sun Jul 27, 2014 12:13 am
Cheers Watermouse for the info defiantly helped out!
Users browsing this forum: Google [Bot] and 152 guests
