| 97 Coily Rear Bushes needs replacement http://auszookers.com/forum/viewtopic.php?f=5&t=47040 |
| Author: | Onderbroek [ Fri Jul 18, 2014 3:05 pm ] |
| Post subject: | 97 Coily Rear Bushes needs replacement |
Hi Guys i need to replace my rear bushes on my coily - it was pointed out to me on my roadworthy test - seeing that i live in South africa i managed to pass the test, even thought the bushes need replacment. ![]() ![]() Now ive been warned against Poly Bushes - so i want to see if i can get rubber bushes. Will the jimny bushes fit in the coily raduis arms? if they do im sure i'll be able ot sourch them locally OR must i order from OZ (expensive parts + expensive shipping) |
| Author: | greenzook89 [ Fri Jul 18, 2014 10:32 pm ] |
| Post subject: | Re: 97 Coily Rear Bushes needs replacement |
I am pretty sure they are the same mate. You could PM Bruce regarding the bushes as I know a few guys who run them and swear by them. |
| Author: | Onderbroek [ Wed Jul 23, 2014 3:21 pm ] |
did have a chat to Bruce but the postage to South Africa is way too expensive - will need to make another plan |
| Author: | PurpleZOOK [ Fri Jul 25, 2014 5:06 pm ] |
You can still get rubber bushes and the kit i got said jimmy/sierra compatible so id assume they are the same . |
| Author: | Onderbroek [ Fri Jul 25, 2014 7:14 pm ] |
PurpleZOOK wrote: You can still get rubber bushes and the kit i got said jimmy/sierra compatible so id assume they are the same . That is good news, where did you buy from? shipping from OZ is very expensive and tried getting them locally but they only have poly bushes, i will keep looking for rubber ones |
| Author: | PurpleZOOK [ Sat Jul 26, 2014 4:27 pm ] |
got em from these guys http://www.ebay.com.au/itm/261045993020 ... 1497.l2649 |
| Author: | Lockie666 [ Sat Jul 26, 2014 5:31 pm ] |
Stay with rubber bushes, polly bushes are to hard and cause breakage of the brackets. |
| Author: | coily96 [ Sun Jul 27, 2014 8:42 pm ] |
Jimny will be the same, keep in mind the radius arms have 2 different size bushes(width and not diameter). The mounts to the chassis are thicker and the mounts to the diff are smaller. |
| Author: | Bruce [ Mon Jul 28, 2014 2:58 pm ] |
Lockie666 wrote: Stay with rubber bushes, polly bushes are to hard and cause breakage of the brackets. NO SOOOOOO Yes the ones you buy from normal shops are too hard. The ones I make are softer and work GREAT. |
| Author: | Onderbroek [ Wed Aug 27, 2014 11:34 pm ] |
Had a local shop mould me some new bushes so im sorted for now ![]()
| Author: | Bruce [ Thu Aug 28, 2014 4:53 am ] |
What are they made of? |
| Author: | Onderbroek [ Thu Aug 28, 2014 2:29 pm ] |
Rubber |
| Author: | bangn [ Thu Aug 28, 2014 2:54 pm ] |
why do the crush tubes look deformed |
| Author: | Onderbroek [ Thu Aug 28, 2014 7:13 pm ] |
Think it might be the photo, he used the original crush tubes |
