Vehicle: Toyota landcruiser 105
Posted: Thu Jul 24, 2014 3:42 pm
Transfer case won't engage front drive shaft, get high/low ratio just doesn't engage the front, no obvious noise or clunking in the transfer case. Any suggestions?
Posted: Thu Jul 24, 2014 3:54 pm
No the shaft doesn't, I jacked it up and engage 4 wheel drive, if u turn the rear shaft it will turn the front by hand but the drive from the gearbox will only transfer through to rear shaft, FWH engaging / disengaging correctly
Users browsing this forum: Google [Bot] and 375 guests
