It is currently Tue Aug 04, 2026 10:20 pm
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Jul 27, 2014 6:25 pm
Hey gang!
I'm doing a G16b conversion ATM and I'm also doing powersteering on it!
I'm having a problem with the lines
I will need to get custom ones made
Who makes them around brisbane?
Do I need to supply the fittings?
Also! I have a flared loose nut fitting that goes on the box end return line, but in the box there is no flare in it to screw down onto! What the?
Post Posted: Sun Jul 27, 2014 6:43 pm
you can do the conversion using all the vit lines, but the are a little too wide in the steel section and you need to get a little creative.
otherwise any hydraulics shop can make custom lines for you.
Vehicle: SWB Sierra
Post Posted: Sun Jul 27, 2014 6:55 pm
^^^agreed, just take you high pressure hose to a hydraulic shop and get them to put the fittings onto a soft line whatever length you need.
Post Posted: Sun Jul 27, 2014 7:19 pm
Have you guys got any info or pics on the fitting in the powersteering box? Return line one
Vehicle: SWB Sierra
Post Posted: Sun Jul 27, 2014 7:44 pm
Not on hand, I can get some tomorrow arvo if no one else has any handy
Post Posted: Sun Jul 27, 2014 7:49 pm
I need the brass concave fitting the return line flared fitting tightens down on
Post Posted: Sun Jul 27, 2014 7:51 pm
Convex sorry
Vehicle: SWB Sierra
Post Posted: Thu Jul 31, 2014 5:31 pm
I had a look at mine today, couldn't see down into the return line fitting properly, too much p/s fluid around. From memory though, I don't think that there was a separate fitting in there at all. Just tighten the return line on and away you go.
Users browsing this forum: Google [Bot] and 350 guests
