It is currently Thu Aug 06, 2026 8:05 pm
Vehicle: suzuki sierra lwb
Post Posted: Wed Jul 30, 2014 10:02 pm
Had a check of my air filter today and not only did it look like it is older than the car itself but it had about 1/2 a cup of white greasy foam in with it .WTF ....... im sure head gasket is fine as the car dosnt use oil .... coolant ..... overheat.....and there is no water or milky residue in the oil itself , theres no sign of oil in the coolant and the car starts and drives fantastic.
But white foam seems to becoming out of the rocker cover and into the air filter via the conecting hose ......
Quick look on google says it could be pcv and sugest cleaning the system ....... how do you clean out the pcv system ????????
Or do I take it to a mechanic .
Craig
Vehicle: Drover pickup turk
Post Posted: Wed Jul 30, 2014 10:06 pm
Remove pcv valve and let it sit in carby cleaner/degreaser, You should hear a little ball bearing inside when you shake it.
I like the tuna here
Post Posted: Wed Jul 30, 2014 10:20 pm
Coooool ...that sounds like an easy fix .... thanks
Users browsing this forum: Google [Bot] and 739 guests
