It is currently Sun Aug 02, 2026 1:46 am
Post Posted: Fri Aug 01, 2014 11:55 pm
Long shot but...
Is there a Vit or GV diff housing that has the pumpkin offset same as Jimny, or are they all centered?
Alternatively, is there a housing from another vehicle that will fit a Vit centre and be close enough to and have the same offset as Jimny?
Post Posted: Sat Aug 02, 2014 12:21 am
nope, but it sounds like you need to see this thread. viewtopic.php?f=14&t=38240
Post Posted: Sat Aug 02, 2014 12:23 pm
Good on you for asking the question and all, but how likely did you think this was?
Vitara is wide. You'll notice that I cut 160mm off of a NT vitara rear housing to end up with the floater the same width as WT sierra. I think they actual WMS difference is 110mm between the two cars.
I would have thought your Jimny is 4.1 ratio. There is no 4.1 ratio Vitara rear.
If your car is 4.3 geared, then I guess you can run a V6 GV manual rear or something to match front and rear... but all the work on the rear - cutting down/brackets etc doesn't fix the tiny front centre or help with gearing.
as both vitara rear and Jimny rear are 26 spline, you could always graft a Vitara rear centre into your Jimny rear axle and use jimny axles/floater/brakes etc, assuming they aren't also a weak link.
Personally, I'd be troubleshooting the front before I bothered with the rear. If the front was built with a Sierra third member and knuckles, you'd then have access to vitara diff gears, cheap 26 spline cromos, and proper wheel bearings. Once that's done, the rear will look like a no brainer.
Post Posted: Sun Aug 03, 2014 10:43 pm
So, that's a no then?
Post Posted: Sun Aug 03, 2014 10:50 pm
Yes, that's a no.
Post Posted: Mon Aug 04, 2014 8:11 am
But not really for just the reasons you asked.
Post Posted: Mon Aug 04, 2014 8:15 am
I could make an offset housing for you easy enough.
Post Posted: Mon Aug 04, 2014 4:10 pm
PM'd.
Users browsing this forum: No registered users and 631 guests
