| cool engine http://auszookers.com/forum/viewtopic.php?f=5&t=47277 |
| Author: | craigtempo [ Mon Aug 04, 2014 8:50 am ] |
| Post subject: | cool engine |
Just wondering where you temp gauge needle sits in the gauge ..... also what is the right temp thermostat to be running in a standard sierra? Im suspicious that my engine is running too cold .my temp gauge sits on about 1/4 . |
| Author: | Scrawny [ Mon Aug 04, 2014 9:14 am ] |
| Post subject: | Re: cool engine |
Should be just under half. Does it fluctuate when on highway and around town? Pretty sure they run an 88 degree thermostat? |
| Author: | J--A--C--K [ Mon Aug 04, 2014 3:47 pm ] |
Sounds like you have the wrong thermostat , I only say this as mine was broken and at the time the closest I could get was 84 I think? And it did exactly as you say. I have no idea of this is bad for the engine or just a little less efficient. But for me was better than over heating all the time. Obviously I have since fixed it. |
| Author: | damagera [ Mon Aug 04, 2014 7:48 pm ] |
problem might be your gauge..just cause it reads quarter ..dont mean its that cold..i would try a 2nd temp gauge and see what temp it really is..just a cheap one from a auto spares shop should do it,,,,BUT as someone else has said .. least its not running hot |
| Author: | atari4x4 [ Mon Aug 04, 2014 7:57 pm ] |
hi OBJ
| Author: | craigtempo [ Mon Aug 04, 2014 9:13 pm ] |
Yeah as stated it running on 1/4 ... this is around town on the highway and when 4wding .im trying to fix a pcv problem (white grey foam ) .ive cleaned out pcv but also found a split in the main hose that runs from rocker cover to the air filter but there is still a small amount of foam being produced so tomorrow im fitting a new pcv and a new hose but I might as well put in a new thermostat while im there .ie engine running cool so not heating up properly therefore producing or colecting condensation. |
