It is currently Mon Aug 03, 2026 8:14 pm
Vehicle: suzuki vitara
Post Posted: Thu Aug 07, 2014 7:14 pm
just wondering if anyone has ran 33s under there vitara putting a 3" calmini lift kit in the zook pretty soon and will be looking to put the biggest wheels under it as possible will 33s fit without to many hassles
Vehicle: SWB Vitara
Post Posted: Thu Aug 07, 2014 9:20 pm
Any body lift with that? Guard trimming or massaging?
Post Posted: Fri Aug 08, 2014 8:05 am
How much breakage do you want with that?
What front diff are you running? What shafts and cvs? Gearing?
There's a LOT of steps to take before putting 33s on a vit.
I would shave a vit rear miles before trying to run 33s on a vit.
How much lift are you planning. It will lose stability and capability with too much lift.
on road gearing will suck. Youll need to do xfer gearing.
youll need to address axle/shaft/cv strength.
And to save Steve having a brain melt.
Suspension lifts dont fit tyres, body lifts, bumpstop spacing and guard cutting does.
Post Posted: Fri Aug 08, 2014 8:11 am
Hehehe unless you're talking about the Calmini kit Jdk, where they use spring bind to take the place of bumpstop spacers, because 'murica!
All the other points are spot on though. With cutting and bumpstop spacing it's possible to run 33's on a vitara with no lift. It's breakage and gearing that's the problem, not fitting the tyres.
Post Posted: Fri Aug 08, 2014 5:11 pm
sounds like i have a bit more saving to do before i start this project then thx for all the advise think i will just run 31s for the moment then
Users browsing this forum: KeVl@r and 77 guests
