Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
burls
Joined: Sun Mar 07, 2010 10:30 pm Posts: 989 Location: Ipswich
Vehicle: 95 sj70 and 78 lj81
 Posted: Fri Aug 08, 2014 7:05 am |
As my rig sits and waits parts I was wondering how difficult it would be to upgrade my 16B(single coil/Dizzy) to the coilpack set up of later models. Has anyone done this and is it worth the effort/cost?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Fri Aug 08, 2014 8:13 am |
I'd say not worth the effort. New cam, cam position sensor, loom, ecu, inlet manifold.... Easier to find a complete coil pack motor. You'd also have to do the water piping too.
JrZook
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
 Posted: Fri Aug 08, 2014 11:32 am |
As Gman said, its basically a whole new ECU system because it requires a few different sensors.
Post up the pics of the differences between the modules in the vit and sierra dizzy's and I may be able to help figure out how to get yours going again. If I'm correct and your engine is an early vitara unit then the pickup in the dizzy is just a simple variable reluctance sensor with a 4 equally spaced tooth pickup wheel. Sierra electronic dizzy's also use that same setup as do a heap of vehicles from 1980-2000's.
I'm not sure what you mean by mirror image tho in your wanted post (hence need pics). If the unit fits in the vit dizzy and you get the spacing between the sensor and pickup teeth nice and tight ie ~1mm then it doesn't matter where the pickup sits in relation to the standard one. The ECU doesnt care where it is as long as the pickup to tooth angle is correct as thats your timing refence point. Obviously this can be adjusted by rotating your dizzy housing or rotating the dizzy shaft relative to the camshaft if its really far out.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Fri Aug 08, 2014 12:00 pm |
yep. coil pack motor.
they can be had pretty cheap
burls
 Posted: Fri Aug 08, 2014 12:10 pm |
Jr
Im gonna try and knock something up on the weekend with the sierra one, but it is definitely not just a bolt in job. If you want to know what I meant by mirror. Put one beside the mirror an you see what I have its exactly opposite bracket goes the other way from the screw holes. I can send you a photo from my phone if you want, but I cant load it up here as usual Im a photo loading nutcase
burls
 Posted: Fri Aug 08, 2014 7:38 pm |
Well it looks like I found a solution, I managed to pry the coil off the sierra bracket and fitted to the the vitara one with araldite. I let it set overnight and see how it fits up tomorrow
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 198 guests
