It is currently Fri Jul 24, 2026 1:43 pm
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Sat Aug 16, 2014 9:13 am
Hi,
Can anyone tell me what the AVM manual hubs are like for a Jimny?
My factory auto locking hubs are not disengaging properly so am thinking of swapping them out.
ARB has quoted me $309 for both front hubs.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Aug 16, 2014 2:32 pm
309 for a pair you mean? 242.66 + shipping from jimny bits fyi incase you were looking at other stuff to ship it together
The avm ones have a plastic centre you twist. Not a problem.
You can also get an adapter and use stock suzuki hubs from oldr models.
Post Posted: Sat Aug 16, 2014 6:30 pm
Thanks for the reply Jezza, I will have a look at Jimny Bits and fond some more things to buy
Vehicle: 08 jimny
Post Posted: Tue Aug 19, 2014 9:13 am
I've run them in a couple of jimnys and never had a drama.... Got both sets from jimnybits
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Aug 19, 2014 10:17 am
AVM 500 Hubs $65 each, had AVM 400 hubs before where more trouble than they where worth usually cause of the smalls crews in the week plastic like cap.
the 500s have been good.
http://www.roadrunneroffroad.com.au/Fre ... itara.html
Post Posted: Tue Aug 19, 2014 11:00 am
aren't AMV hubs are only good for saving a CV as they'll break before a CV... all well & good apart from the fact that you can't get replacement parts easy, do they also randomly fall off like the mile marker hubs?
:hey: Mr OP, search for "vitara locking nut" posts by jonno_racing.
pretty sure he uses the vitara locking nut assembly on the wheel bearing to eliminate the jimny set up & so you don't have to grind down the jimny one & then bolt up sierra FWH as if you were fitting them to a sierra, best thing about the aisin FWH is they share many common internal components with ALL aisin FWH, so you can potentially get spares from any japanese 4wd with aisin FWH.
Post Posted: Tue Aug 19, 2014 8:18 pm
Thanks Gecko, do they ones in the link just bolt straight on? Given that they are for a vit?
I have just found out about the Aisin hubs, my workmate has them on his Hilux. Does Aisin makes FWH that bolt straight onto a Jimny?
I don't want to be putting something like vitara hubs on, or spacers, or anything like that. I just want something that is a direct bolt on
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Aug 19, 2014 8:28 pm
With the spacer aisin are bolt on, which is the point of the spacer.
As far as im aware more people have baged out the avm hubs for various reasons then have actually had a problem letalone run them.
Post Posted: Tue Aug 19, 2014 8:32 pm
Jezza86 wrote:
With the spacer aisin are bolt on.
Which Aisin hubs do you refer to here and also where can I get a spacer?
Post Posted: Tue Aug 19, 2014 8:34 pm
lolwot, did you even bother to search for the info i suggested? i'd rather use factory parts than some random manufacture that is almost impossible to find spare parts for in a pinch.
Post Posted: Tue Aug 19, 2014 8:39 pm
and if you don't like the thought of putting vitara bits on your jimny then you can't use these AVM's as suggested by gecko-xl7 as they also suit a vitara, sierra & a samurai. :deadhorse: OMG
just seen the price, could buy many sets of aisin FWH's & have a life time of spare parts if you ever required them.... all for the cost of just a pair of AVM's
Post Posted: Tue Aug 19, 2014 8:53 pm
Before this thread I had absolutely no clue what would and wouldn't fit. Let me just put that out there. Obviously (now that I know what does and doesn't fit) if using the vitara hubs is the best way then I'll do that.
So (correct me if I am wrong) the Aisin hubs will require a spacer to work on a Jimny?
Post Posted: Tue Aug 19, 2014 8:56 pm
i'm not a jimny person, just some how manage to absorb useless info such as this... best you do your own research, and if you notice i didn't actually mention vitara FWH's, but the vitara locking NUTS. :wink:
Post Posted: Tue Aug 19, 2014 9:10 pm
I have tried searching for that thread that you mentioned, couldn't see anything though. All I really need to know now is can I only run Aisin hubs for a (I'm assuming) sierra with a spacer. Surely someone has done it and can tell me
Post Posted: Tue Aug 19, 2014 9:13 pm
FML :deadhorse: viewtopic.php?f=5&t=29951&hilit=nut
Post Posted: Tue Aug 19, 2014 9:14 pm
There's no better hub than an Aisin.
Armsup
Post Posted: Tue Aug 19, 2014 9:20 pm
:hey:
jonno_racing wrote:
Just putting it out there... all i need to do is run vitara/sj80 bearing nut and retainer.. not a custom part. also allows me to use the bearing tool i already have and standard hub bolts that are common..
no custom bits. no adapters, just factory Suzuki parts. in fact this lets me to use 100% factory parts and NOT introduce custom parts/bolts etc.
Post Posted: Tue Aug 19, 2014 9:21 pm
:no:
Bugsta wrote:
As I am using FWH AND Sierra CV's I had to have quite a thick spacer, 16mm. The spacer is sealed and grub screwed to the locking hub, and sealed to the wheel hub. The 6 holes are a tight fit for minimal movement around studs (not bolts). These studs have a finer thread on the outside for better tightening.
When I had a rough cut 10mm spacer and bolts, I was always breaking bolts. The holes were too sloppy. I have not broken a stud with the new system since. Except to say I stripped the thread because I overtightened one when tensioning. They do need tensioning every so often.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Aug 19, 2014 9:23 pm
My life lol.
You can go eiyher way its up to you nick.
If the aisin hubs are indeed stronger then a avm then its possible a avm may break if yo droped a spinning wheel onto a grippy surface. But ive done this a few times being unlocked and havent had any ill effects and I have the nockoffs of the avm hubs...
Post Posted: Tue Aug 19, 2014 9:27 pm
the lack of spare parts is my concern with the AVM's
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Aug 19, 2014 9:28 pm
In saying that id prefer to break a hub and put a spare on then break a cv and not have a spare
Thing is you can pack out the old airhubs with grease so their drive flanges and bolt em back on if something did break.
Post Posted: Tue Aug 19, 2014 9:42 pm
Thanks Atari and Jezza. Very useful information. You have answered my questions
Post Posted: Tue Aug 19, 2014 9:44 pm
I'll throw in my two cents worth.
I've been running the same set of refurbished used Sierra Aisin hubs for about 4 years. I used spacers from BigJimny.com and haven't had any problems with the setup. BenT has spacer rings for sale here
http://www.auszookers.com/forum/viewtopic.php?f=15&t=15009
Post Posted: Wed Aug 20, 2014 8:27 pm
jimnybits sells them too
http://www.jimnybits.co.uk/shop/jimny/d ... d_610.html
Post Posted: Wed Aug 20, 2014 8:47 pm
Thanks Zukenutter, the exact info I was looking for.
BertZook wrote:
Thanks, I'll have a look
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 314 guests
