It is currently Thu Jul 23, 2026 8:21 pm
Vehicle: 97 Vitara
Post Posted: Wed Aug 20, 2014 9:23 pm
Can you body lift a AUTO SWB VITARA 97 ????????
Any thoughts appreciated Cheers
Post Posted: Wed Aug 20, 2014 9:29 pm
yous da sierach nwoobe
Vehicle: 97 Vitara
Post Posted: Wed Aug 20, 2014 9:45 pm
less mushies bro
Post Posted: Wed Aug 20, 2014 10:09 pm
and there is your answer, somewhere in there... http://www.auszookers.com/forum/viewtopic.php?f=4&t=555
more shrooms. :peaceout:
Vehicle: 97 Vitara
Post Posted: Wed Aug 20, 2014 10:55 pm
calmini the answer atari ?
Post Posted: Wed Aug 20, 2014 11:42 pm
no it's not the answer but it's a pretty good solution to the vitara if you sort out the short comings of the kit... but the answer to the original question is in that thread though.
here is a pro-tip: open that link, use the lil search for panel above the first post on top of each page on a thread, punch in auto & have a read, then maybe even try bodylift & have a quick suss of the results, don't let me down... i know you can find the answer. :wink:
Vehicle: 97 Vitara
Post Posted: Thu Aug 21, 2014 9:30 pm
cheers read for an hour+
I think i worked out that you can body lift vitara SWB auto, so if i'm still experiencing rubbing of my 31's after 3" FTS lift then 2"BYE body lift will be on the cards.Cheers atari for your help, by the way any thoughts on the FTS lift only using as a pig chaser out west and need height. nwoobe
Post Posted: Thu Aug 21, 2014 10:22 pm
see it's not that hard, the info is out there & the search works & works well + my spoon is broke.
an auto is easier the BL, than a manual as you don't have to worry about the manual shifter, the FTS struts haven't had a good wrap from what i've seen over the years, as i said to some other greenhorn the other day, if you're not fussed... cut that bitch like it owes you money.
Vehicle: 97 Vitara
Post Posted: Thu Aug 21, 2014 11:32 pm
i'll post a photo with FTS next week thanks for advice.
Users browsing this forum: Google [Bot] and 265 guests
