| Jimny front diff, what is this pin? whats the procedure? http://auszookers.com/forum/viewtopic.php?f=5&t=47489 |
| Author: | Flippa [ Thu Aug 21, 2014 12:55 pm ] |
| Post subject: | Jimny front diff, what is this pin? whats the procedure? |
Hey guys, I was messing arround with the jimny on the weekend, nearly boxing it up after the sr20 install and I must have had a few beers too many coz i decided to pull this out of the front diff to see what it was, I have rebuilt the diff with trial jimny axles and cvs (26 spline) and used rear jimny side gears to suit) they've also had every bearing, seal, etc replaced though I left the centre open as per factory as I am not a big fan of locking the fronts personally. Anyway I have attached a picture of what I have removed, And quickly realised I shoudln't have, though perhaps considered the work I have undertaken I should find the procedure to what FB grops tell me is a backlash adjuster? I've been all over google and in the manual and I cant find anything... is anyone able to shine some light on this? Thanks again The pin and its lock nut are # 22 / 23 respectively
| Author: | tanshi [ Thu Aug 21, 2014 1:01 pm ] |
| Post subject: | Re: Jimny front diff, what is this pin? whats the procedure? |
its called a thrust bolt |
| Author: | tanshi [ Thu Aug 21, 2014 1:06 pm ] |
it says tighten bolt in to 1.5NM back it off half a turn hold the bolt still and tighten the nut (with locktight)on it to 85NM |
| Author: | Flippa [ Thu Aug 21, 2014 1:11 pm ] |
thankyou sir, thats basicly what i did by guessing after id removed it but i will use that exact torque and redo this weekend. much appreciated. |
