It is currently Sun Jul 26, 2026 9:52 am
Vehicle: 93 Vitara
Post Posted: Sat Aug 23, 2014 4:08 pm
Hey guys,
Anyone changed a fuel filter on a 93 lwb vitara 1.6 efi?
jus wondering where is it and how tricky to change it?
Post Posted: Sat Aug 23, 2014 4:26 pm
It's up near the tank, on the inside of the RHS chassis rail. (From memory)
not that tricky to change, The lines are attached by banjo bolts, so don't loose the little copper washers or it will never seal.
Vehicle: 93 Vitara
Post Posted: Fri Aug 29, 2014 5:47 pm
Thanks a lot.
Do you need to stall the engine to clear the lines and disconnect pump or can you just remove fuel cap to release the pressure, don't really know which fuse it would be for the pump?
Post Posted: Fri Aug 29, 2014 5:57 pm
No. There's a procedure for depressuring the lines but I don't bother- be aware though that fuel will spurt about a bit once you crack a banjo bolt.
Vehicle: 93 Vitara
Post Posted: Fri Aug 29, 2014 6:44 pm
Cheers for your help mate will giv it a go.
Users browsing this forum: No registered users and 52 guests
