http://auszookers.com/forum/
Vitara Fuel Filter Change?
http://auszookers.com/forum/viewtopic.php?f=5&t=47505
Author:  Paulie [ Sat Aug 23, 2014 4:08 pm ]
Post subject:  Vitara Fuel Filter Change?
Hey guys,
Anyone changed a fuel filter on a 93 lwb vitara 1.6 efi?
jus wondering where is it and how tricky to change it?
Author:  Gwagensteve [ Sat Aug 23, 2014 4:26 pm ]
Post subject:  Re: Vitara Fuel Filter Change?
It's up near the tank, on the inside of the RHS chassis rail. (From memory)
not that tricky to change, The lines are attached by banjo bolts, so don't loose the little copper washers or it will never seal.
Author:  Paulie [ Fri Aug 29, 2014 5:47 pm ]
Thanks a lot.
Do you need to stall the engine to clear the lines and disconnect pump or can you just remove fuel cap to release the pressure, don't really know which fuse it would be for the pump?
Author:  Gwagensteve [ Fri Aug 29, 2014 5:57 pm ]
No. There's a procedure for depressuring the lines but I don't bother- be aware though that fuel will spurt about a bit once you crack a banjo bolt.
Author:  Paulie [ Fri Aug 29, 2014 6:44 pm ]
Cheers for your help mate will giv it a go.
