Joined: Sun Nov 27, 2011 2:51 am Posts: 38 Location: Perth Wa Baldivis
Vehicle: 2004 XL7 , 94 SWB Vit
Posted: Sun Aug 31, 2014 2:10 pm
Hey Guys I have a 94 SWB vitara and do a lot of beach work I recently had the clutch not disengaging , and after a bit of research I decided that whatever I would have to pull the gearbox .Much to my surprise I found that it was literally full of sand and the clutch had seized solid onto the flywheel . I have removed the clutch , Pressure plate ,thrust bearing and spigot bush and will replace the lot, now all I need to find out is how to seal the bell housing . Does any body know if it will affect the clutch if I plug all the drain holes to prevent any more sand entering . regards Daz
Users browsing this forum: No registered users and 40 guests
