| Sand in bell housing http://auszookers.com/forum/viewtopic.php?f=5&t=47605 |
| Author: | xl76 [ Sun Aug 31, 2014 2:10 pm ] |
| Post subject: | Sand in bell housing |
Hey Guys I have a 94 SWB vitara and do a lot of beach work I recently had the clutch not disengaging , and after a bit of research I decided that whatever I would have to pull the gearbox .Much to my surprise I found that it was literally full of sand and the clutch had seized solid onto the flywheel . I have removed the clutch , Pressure plate ,thrust bearing and spigot bush and will replace the lot, now all I need to find out is how to seal the bell housing . Does any body know if it will affect the clutch if I plug all the drain holes to prevent any more sand entering . regards Daz |
| Author: | jdk81 [ Sun Aug 31, 2014 5:40 pm ] |
| Post subject: | Re: Sand in bell housing |
Leave it as is, and pull the cover plate every so often and hose it out? |
