Pretty simple to fit. Just think it through. 1. remove brake drum. 2. pull axle shaft. 3. press off brake backing plate 4. refit bearing to axle (new Brg + retainer) 5. fit caliper bracket to axle housing 6. install axle 7. fit rotor plate, and disc rotor 8. fit caliper. 9. bleed brakes
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 305 guests
