Joined: Mon Oct 27, 2008 10:30 pm Posts: 1006 Location: Cervantes WA
Posted: Tue May 05, 2009 3:54 am
had a look under my jimny yesterday to find i had sprung a leak!
only a small one but it looks like the oil is coming out where the drive shaft joins onto the transfer spraying the stuff all over the underside of my car.
gave it a degrease today to make sure that is where the oil is coming from.
just wondering would anyone know where i could find a exploded diagram for a jimny transfer gearbox on the internet.
not sure if they change at all but its a sep 01 jimny
one with two sticks (not the push button 4wd)
Joined: Tue Jul 03, 2007 11:30 pm Posts: 1350 Location: stuck in a hole. not off road, just deception bay.
Posted: Tue May 05, 2009 12:56 pm
from what you have described it is just the input/output shaft seal.
the case doesn't need to be stripped to replace it.
remove the drive shaft, remove the flange (on a sierra you need a 27mm socket and a bloody good rattle gun, not sure on the jimny though) then you will be able to prise the old seal out with a screwdriver and then fit the new one.
Posted: Sat May 16, 2009 12:28 am
as i said degreased around my transfer case last week and toped up the oil. (took 200ml)
then left it for a wile to see where the leak was coming from.
looks like its coming from "here" (see pic) its a pretty slow leak but
does this look like its the input/output shaft seal you were talking about "mrw82"?
thanx ben
Joined: Sun Nov 21, 2010 11:35 am Posts: 6 Location: Brisbane
Posted: Sun Dec 05, 2010 9:38 am
just thought i would post this link, thought it might help... "http://auszookers.com/index.php?name=Forums&file=viewtopic&t=7732&highlight=transfer+leak" (hope i'm linking to other threads the right way)
Posted: Sun Dec 05, 2010 9:44 am
Users browsing this forum: No registered users and 232 guests
