It is currently Tue Jul 28, 2026 7:08 am
Post Posted: Thu Sep 04, 2014 8:58 pm
Just considering this as an option for my lwb. Thought there was a few guys here running similar setups.
I need a bit more length out of my rear springs. From memory hilux leafs are 5mm wider than sierra springs and need to be ground down a little ????
Vehicle: Drover pickup turk
Post Posted: Thu Sep 04, 2014 9:13 pm
60mm wide AFAIK
Fatzook did it
JDK has put them in his SWB.
I like the tuna here
Vehicle: sj51
Post Posted: Thu Sep 04, 2014 9:31 pm
I had lux fronts in ond of my old zooks, 60mm wide as stated
Post Posted: Fri Sep 05, 2014 8:02 am
Just check that 60mm - i believe they're actually 63.5 or something.
Also - Diesel hilux leaves are rated heavier (fronts, not sure about rears) - Petrol are the way to go.
Rather than grinding the leaf down and risking a fatigue point, you could make stepped shackles? But given the length of a hilux rear you'll likely need to weld on new hangers anyway. They also have an offset center pin i believe?, so axle position needs to be considered.
Users browsing this forum: rob_macca67 and 538 guests
