Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
yareckonillgetupthat
Vehicle: 1994 sierra
 Posted: Sun Sep 14, 2014 5:24 pm |
may be a noob question just wondering if anyone can help I'm trying to install a locker in my rear diff I've removed drums ,tail shaft that big ass bolt after tail shaft now I'm stuck i can't get axles out and I'm not sure how to get to the c clip as the third member won't come away can anyone help me its a 1996 sierra thanks in advance
swifty_ano
Joined: Tue Jun 29, 2010 4:17 am Posts: 1664 Location: Brisbane, QLD
 Posted: Sun Sep 14, 2014 5:30 pm |
So the axles wont come out? Have you taken the 4 nuts off behind the drum?if you have, then you have to "slide hammer" the axles out. Will go into more depth if you have taken those 4 nuts off
 Posted: Sun Sep 14, 2014 5:47 pm |
na i havent i didn't think i had to oops ,once i get centre out i think ill take it to my mechanic to install locker ,thanks mate
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Sun Sep 14, 2014 6:01 pm |
Hmm, you probably should have done a bit more research before you got carried away undoing things there - if the pinion bearings and seal were sound, the last thing you should have done was undo the pinion flange nut. You've now lost preload and will need to set the pinion up with a new crush sleeve - money and time wasted.
As per swifty - you'll need to undo the brake had lines to the drums, remove the 4 backing plate retaining nuts and with a slide hammer (or with the car well supported on chassis stands, use a wheel and tyre loosely attached) knock the axles out.
Then you can remove the third member retaining bolts and prise the third member out.
Steve
 Posted: Sun Sep 14, 2014 6:50 pm |
Cammopricey
Joined: Mon Oct 15, 2012 7:22 am Posts: 54 Location: Hamilton vic
Vehicle: Suzuki SJ70 & SJ51T
 Posted: Wed Sep 17, 2014 7:00 pm |
You can use the drum on backwards or even the wheel to help pull out the axle if the 4 centre bolts are done up
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 283 guests
