It is currently Sun Aug 02, 2026 1:46 am
Vehicle: 92 model Sierra/Vitara 1.6Efi
Post Posted: Sun Sep 14, 2014 6:37 pm
OK tech heads, who is the smartest man alive?
The one who can answer this simple question.
Why does my 92 Sierra creep forward as it starts, even though the gearbox is in neutral? If the clutch is depressed as the key is turned, it doesn't happen.
Thanks,
Ted.
Post Posted: Sun Sep 14, 2014 6:45 pm
do you have transfer gears, could this be the famous suzuki circle spin ratio?
Vehicle: SJ80, SE416
Post Posted: Sun Sep 14, 2014 6:52 pm
Hydraulic action inside the gearbox applies a small amount of force on the gears when not engaged.
Not good practice to start a car without a brake applied.
Post Posted: Sun Sep 14, 2014 6:58 pm
When I had the 660cc manual with 6.4 transfer gears and 5.12 diffs in my car it would move dramatically if started in neutral.
Even my F250 does it.
Post Posted: Sun Sep 14, 2014 7:10 pm
:deadhorse: you guy's suck, 303zuke would have been down. :rofl:
Post Posted: Mon Sep 15, 2014 11:12 am
Yeah mine drives itself with 6.5's/4.6's.
Post Posted: Mon Sep 15, 2014 1:23 pm
This, it is known.
Post Posted: Mon Sep 15, 2014 7:38 pm
This.... pompoms
Thanks guys. I do have 6.5 gears in the transfer. Would a lighter weight oil stop this? In Winter, on a cold morning, it is enough that unless I sit in the vehicle and depress the clutch, the bloody thing won't start.
Cheers,
Ted.
Post Posted: Mon Sep 15, 2014 7:42 pm
That sounds excessive. This wasn't a problem even with 5.12 diffs and a teeny tiny 660cc motor in Piggles.
What oil weight do you have in it now?
I wouldn't recommend going heavier than 80-90W although for a while there 140W was flavor of the month.
Vehicle: Daisy
Post Posted: Mon Sep 15, 2014 8:52 pm
This can be useful sometimes, I had a clutch cable break one day and had to stop at some lights near home, 6.5s meant it would drive forward in low range just from the pressure on the synchros and I got it all the way to 5th where I engaged the gear and limped it home!
Post Posted: Tue Sep 16, 2014 5:32 am
Yeah, I would have thought so too Steve. I'm running 80-90W in it, which is pretty much standard. Like I said, it is only during the colder Winter period, but a pain in the arse. Being a 1.6EFI one would think that it would start OK. If I don't sit in it and depress the clutch, I may have to (reaching through the window) start it up to five times before it will run.
Thanks anyhow guys. At least I now know it isn't a problem I need to be concerned about.
Cheers,
Ted.
Users browsing this forum: No registered users and 633 guests
