It is currently Tue Oct 27, 2026 4:18 am
Post Posted: Fri Sep 26, 2014 8:35 am
Ok so to the informed. how much pressure/flow does a hydro pump need to pump to run Full hydro steering? will the average pajero pump keep up? and how much power is it likely to sap from an engine? will it be a huge amount more than normal power steering?
I would only be looking at running a 6 inch ram
Post Posted: Fri Sep 26, 2014 9:52 am
6 inch by what diameter? Shouldn't be much greater sap from the engine than normal power steering.
This and the other two parts will give you heaps of information: http://www.pirate4x4.com/tech/billavist ... _Steering/
Post Posted: Fri Sep 26, 2014 9:54 am
probably only 1.5 inch, looking to keep it small and light.
i'll probably look into what Rhett is running on micro as it will still be zook diffs sorta
Post Posted: Fri Sep 26, 2014 9:59 am
1.5 is pretty small, you won't have a huge amount of power.
Matching your valve to the ram is more important than the pump which can be changed out later with no effect to the rest of the system.
Post Posted: Fri Sep 26, 2014 11:55 am
I don't really want too much power as ill have issues with king pins and other steering components snapping off
Users browsing this forum: No registered users and 78 guests
