It is currently Fri Oct 23, 2026 8:23 pm
Vehicle: Suzuki sierra jx
Post Posted: Mon Oct 20, 2014 5:54 pm
Hi guys hoping someone can help me out here so I have 1990 sj70 g13. So I went 4wding in the weekend and got stuck in a bog and got a bit bumped up and was fine most the way home but whe I got back to the city it seem to be having a whining noise coming from the front a believe as only does it after 30kpm and up I have change gearbox oil it was fine, transfer was milky but have drained and refilled that to both have been filled with vmx 80 and some g70. It seem to be worse under load but is still there but not as bad and responds to getting on and off accelerator. I did also notice my clutch was a little stiff after coming out of the bog.
Any help would be much appreciated.
Cam
Post Posted: Mon Oct 20, 2014 6:22 pm
Bit hard to understand. Is the whining engine related (changes with revs)? Or road speed related (changes with speed)?
Post Posted: Mon Oct 20, 2014 6:27 pm
Only happens after I get over 30 odd k but i can hear the difference between on and off trotle. It's still there but it sounds worse under load
Post Posted: Mon Oct 20, 2014 6:41 pm
Are the front hubs unlocked?
Post Posted: Mon Oct 20, 2014 6:44 pm
Yup I have while stationary I have locked and unlocked them a couple of times
Post Posted: Mon Oct 20, 2014 6:53 pm
Seems to be when in 3,4,5 gear
Post Posted: Mon Oct 20, 2014 7:05 pm
http://vid1292.photobucket.com/albums/b ... 8dz6wz.mp4
Vehicle: 92 Sierra bars F&R locked
Post Posted: Mon Oct 20, 2014 8:12 pm
transfer case. mine does it really bad
Post Posted: Mon Oct 20, 2014 8:15 pm
Yea I just found a forum then sayin to put transfer in netural and run thru gear looks like I fucked my transfer case in the weekend
Users browsing this forum: No registered users and 256 guests
