It is currently Sat Nov 14, 2026 1:32 am
Vehicle: jimny 2010 auto
Post Posted: Fri Oct 23, 2020 6:18 pm
i tore one of the sensors off the transfer case i replaced it still cant et in to low range.car works fine in high range but low range light flashes and beeps please help
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Feb 10, 2021 9:53 am
Did you get it going?
I had a similar problem and it caused me a lot of angst! Eventually hooked up a set of LED's off the 4WD computer, and some bypass switches (no easy task) so I could see what was happening with all the interlocks, and sussed it that way. The vacuum switches ended up the problem, or rather the vacuum tubing (switches indicate the hubs are happy or not).
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 65 guests
